Sprinkler system advice
Old 04-14-16, 02:51 AM
L
I have an 18ft x 44ft patch of grass that I'd like to run a very basic sprinkler system for. I'd like to run PVC under ground to 3 heads. I'd like to buy a timer and hook the pvc straight up to the timer with a small hose. My water pressure is about 60 psi. Would I be able to run all 3 heads at the same time on 3/4'' pvc lines and get an 18ft radius of coverage?
Old 04-14-16, 06:07 AM
P
Received 1,954 Upvotes on 1,750 Posts
Whether or not you can cover your yard with three heads depends both on your water pressure and flow volume. Without knowing both it can't be calculated. 18' radius (36' diameter) is quite large for a residential system and I doubt you will be able to run all three at the same time, especially if feeding them from a 3/4" line.
Check out the Rainbird website. They have a free irrigation system design service that will do the planning for you.
Old 04-14-16, 06:17 AM
P
Temporarily Suspended
PVC isn't used for that. It's called Poly Pipe which is short for something but I don't remember that.
Old 04-14-16, 06:57 AM
L
The pressure is 65 psi and the flow is 10 gallons per minute
Old 04-14-16, 07:00 AM
L
Poly pipe is an option... but yes pvc is commonly used to run sprinkler lines.
