EZ fix for PVC pin hole leak.....??
Old 05-08-17, 10:39 AM
Y
Received 12 Votes on 12 Posts
This is one inch PVC. Not much coming out..now. This is not the usual cut-off and glue in new piece. Threading fittings; glued fittings; elbows; close coupled pieces all going to a hose bibb.
After I shut off the water supply...is there a way to create a suction or vacuum in the line and apply primer and/or PVC glue...so it is sucked into the pin-hole and provide an easy fix ?
Thanks in advance
Old 05-08-17, 10:45 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
This is a pressure line not much you can do except replace. A piece of rubber (like a tire tube) under a clamp might hold it,
Old 05-08-17, 10:55 AM
Received 330 Votes on 293 Posts
Years ago my youngest son bought mobile home where some yahoo had tried to patch the commode supply line with electrical tape and a hose clamp I had to rip out and replace the floor after replacing the failed plumbing.
Old 05-10-17, 09:32 AM
Y
Upon further reflection....I have decided to go traditional and cut out bad portion ...and replace.
Thanks for the replies.
