Raising sprinkler heads for new flower bed
Old 09-21-17, 12:16 PM
Hello,
I created a flower bed all along the backyard fence - added soil/compost and mulch. Only afterwards I realized that the sprinkler heads would be too short to clear the new height.
How do I go about raising the pop out part so it would clear the new height?
Thank you much
Old 09-21-17, 12:23 PM
If you no longer need the pop-up feature you can just replace your pop-ups with longer riser pipes and put the sprinkler emitter on the top. That cuts down on leakage and maintenance of the pop-up. If you want to raise your existing pop-ups simply unscrew them and install riser pipe underneath. Most are 1/2" NPT.
Old 09-22-17, 03:25 AM
Marq1's Avatar
They come in a solid or cut off variations.
Old 09-24-17, 02:58 PM
If you want your sprinkler heads to be flush with the ground, at rest........you can buy new ones that have a higher head when watering, and go down to ground level when off.
