Tree root problems.
Old 05-02-18, 01:09 PM
E
Received 7 Upvotes on 7 Posts
Tree root problems.
I have somewhat of a problem in part of my yard and I'm asking for advice to fix it. Underneath some large ash trees the roots from those trees have become very noticeable and quite annoying when I mow with my John Deere. Is there something I can do to fix that area? Cutting the roots away is not an option as that would only cause damage to the trees and eventually lead to them dying. One of the roots is sticking out about 4 inches above the ground. Thanks for any advice you can give.
Rich
Old 05-02-18, 04:06 PM
P
Received 2,180 Upvotes on 1,950 Posts
1. You could raise your mower deck.
2. You could bring in some soil to level the area.
Old 05-02-18, 04:41 PM
Received 1,267 Upvotes on 1,207 Posts
3. You could remove the trees and the roots.
Old 05-02-18, 06:55 PM
Received 3,976 Upvotes on 3,569 Posts
I have the same problem with large oak trees. The roots are coming to the surface for water.
Adding soil is the easiest solution.
Old 05-03-18, 04:41 AM
D
Received 258 Upvotes on 206 Posts
I'm no expert on this but if I were going to fix this (I have the same problem in my yard with large live oak trees), I'd just bring in some soil. Then you'll need to seed with grass so the soil wont wash away & it'll look nice... obviously.
