Help with removing excess water from dug hole
Received 0 Votes
OK, so I am putting in a disappearing water fountain in my front yard flower bed. I made the mistake of using a 50 gallon preformed pond insert which failed and dumped most of the water into the 18" deep hole I dug for the insert. My new goal is to remove the water that has saturated the ground and back fill with dry soil, then re-dig a shallower but much wider square hole to lay in my new basin.
My problem is that we have been inundated with daily showers which fill the hole back up with water. I did place a tarp over the area, but for some reason it managed to find it's way back in. I finally got the water to stop flooding back in and removed most of the water that was in the hole, but being that the ground was saturated previously, water is seeping out of the ground and into the hole. I have kept it uncovered whenever the sun was out, but that does not last very long.
Short of waiting until the dirt and ground finally dry up (which could take weeks), I read that using calcium oxide in the hole could speed up the process. The hole is now around 24" in diameter and roughly 24" deep. I understand the dangers of calcium oxide and the precautions necessary in using it. Just wondering if anyone else has had a similar problem with standing ground water. Any suggestions would be greatly appreciated.
If you are getting a lot of rain and the ground is saturated there aren't any easy fixes. You can bail or pump out the hole to hopefully bring the water table down in that area and allow the soil to dry faster. If you want to get working on the new pond sooner you can back fill the hole with crushed stone. It will not be affected by water like soil is.
Received 0 Votes
If you want to play with the lime then go ahead. It will turn solid but you'll be left with a hard lump. Crushed stone will have the load bearing capacity to support your new pond while still being easily dug or shoveled out as needed. But quicklime can be fun to play with if you've never done it before especially if you have kids who like to see it magically steam. So, also be careful as it can get very hot when it reacts with water.
Received 0 Votes
After all the rain (about three weeks of daily rain) the sun came out for about two to three days and I finally got the hole dried up enough to put a layer of gravel down. I then filled and tamped every three to four inches with dirt/soil. I ended up filling in the hole completely. When I was satisfied that the ground was compacted enough, I then re-dug my hole for my Disappearing water fountain basin.
