Retaining wall drainage
Received 0 Votes
I am building a 3.5 foot retaining wall using blocks with locking lip. I put 4 inch perforated pipe at bottom of base. Then backfilled with 57 limestone. I have one row to go. But it rained last night. And when I went out to work on wall I noticed water at the base of the wall. I have clay soil. I was wondering if that is ok. Or if I can add another drain pipe along the base of wall on the outside. By the way, I have about 2 feet of backfill behind the wall and the blocks I am using are 8 in. Tall, 18 inches wide at the front, about 80 pounds each. Thanks
Clay holds water very well so it's not unusual to see puddles after a rain. You want the ground sloped so the water drains away but I wouldn't do anything drastic like installing drain pipe on the outside of the wall.
If you will be planting grass or other plants atop the retaining wall I usually stop the stone about 8-12" below final grade so there is soil for the plants.
Received 0 Votes
The water was coming out from behind the wall, through the base blocks. And settling. There wasn't a lot of water. But when I vacuumed the small puddle, I could see more water coming from behind the wall.
