Leaking Hunter PGP Sprinkler
I was out re-adjusting some of my sprinklers, and one of them was a couple turns loose on the threaded pipe fitting in the ground. So I tightened it up, and now two of the sprinklers on that zone are leaking thru the cap threads. Obviously there was a leak on the pipe threads before and since I tightened it, the extra pressure is causing the cap threads to leak. Do these units have to be replaced, or will new seals fix this?
I have been buying them on eBay for around $6 so have no idea of the repair cost,
BTW they now have the Ultra heads where you can actually remove the nozzle without destroying it, the nozzles are not interchangeable so watch what you are buying.
Haha I hear you, it is easy. But it just seemed a bit easier to replace a seal rather than the whole unit then mess with the arc and distance adjustments again.
Hi, which model head are you dealing with? Sorry, I now see you have PGP heads, this link m@y be of some help.
https://www.youtube.com/watch?v=_PepIotervU
Geo
Geo
