Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Lawns, Landscaping and Outdoor Decor
Reload this Page >
Shouldn't this line drop further down in the gas tank to my weed trimmer?
Old 10-15-18, 12:48 PM
I've recently not been able to get fuel up into the primer bulb there then noticed how short the line is. Or is it not supposed to work unless you've filled it up?
Old 10-15-18, 03:26 PM
W
There should be two fuel lines. The intake line has a filter on the end and should be long enough so that the filter rests on the bottom of the tank. The return line from the primer bulb only needs to be long enough to return fuel to the tank.
Old 10-16-18, 12:17 AM
Received 3,168 Likes on 2,845 Posts
It looks like the black line is the fuel supply while the clear one is the return.
Old 10-17-18, 07:54 PM
Thanks. Whatever. I'll just replace it with a longer cut of tube if I ever get to it
