Rotor sprinkler head removal tool
Old 05-04-19, 01:57 PM
Is there a cheaper version of this plier with an angled jaw?
I have a rotor head that is deep in the grass and I'd like to avoid digging out grass to get to it.
The Channellocks are great, but they are parallel to the ground, and this one is much more angled.
https://www.amazon.com/KEYFIT-Sprink.../dp/B00UIBXLL6
Old 05-04-19, 02:23 PM
P
Received 681 Votes on 628 Posts
I've never found use for that tool. Most heads can simply be unscrewed. If tight a regular pair of Channel Lock pliers works well. The problem I find is that dirt gets on the pipe and fitting down in the ground if you don't dig out around the sprinkler. So, I always dig at least some when replacing.
Old 05-04-19, 03:27 PM
Just planning ahead, if I get some dirt in the pipe, can I unscrew the top of the rotor sprinkler and let water run out, then screw it back in?
Old 05-04-19, 03:29 PM
pugsl's Avatar
Received 74 Votes on 67 Posts
I agree with Pilot dirt will always get into pipe and if not flushed will clog sprinkler.
Old 05-04-19, 03:32 PM
pugsl's Avatar
Should be able to, most heads will come apart.
Old 05-04-19, 11:41 PM
Marq1's Avatar
Received 393 Votes on 367 Posts
The secret is to dig out a "cone" of dirt a couple of inches deeper than the bottom joint so when removed the entire head is exposed and any dirt fall below the joint.
Then you just re-insert the cone and it doesn't even look like anything was disturbed!
YaddaYadda voted this post useful.
Old 05-05-19, 06:28 AM
P
I don't like letting any dirt touch the threads or get into the sprinkler. Yes, you can remove the head and try to blow out the dirt but that sometimes doesn't work very well. Worse is when dirt gets on the threads as it can cause sealing problems with plastic body sprinklers. You really need clean threads when dealing with plastic parts.
Old 05-05-19, 08:53 AM
Received 1 Vote on 1 Post
A little pricy for that plyier thingie. A little digging is a lot cheaper. I use a small pail of water to rinse off the sand.
Sid
Old 05-05-19, 09:16 AM
2
Received 53 Votes on 45 Posts
When I have to remove a sprinkler head (or just trim overgrown grass in the spring) I use a bulb planter like this:
https://www.amazon.com/Fiskars-79836...gateway&sr=8-7
to create space around the head.
