Rainbird ESP-M Rain Sensor Not Detecting Rain
Old 08-10-20, 02:34 PM
I noticed the sprinklers were off even during a recent rain storm. If I hold down the button at the top of sensor (https://www.rainbird.com/products/rsd-series-rain-shut | Manual: https://www.rainbird.com/sites/defau...06/man_RSD.pdf), the Rainbird ESP-M controller does indicate the sensor is 'working'. However, even during the recent major rain storm, the sensor did not register rain. I am not sure how old the rain sensor is but I would assume it needs to be replaced but it is interesting it does register with the plunger pressed.
If I have to replace, the manual isn't clear how to replace the bracket version. The Conduit version seems to just be plug-n-play via screwed on.
Old 08-10-20, 06:02 PM
Received 1,021 Votes on 947 Posts
Did you mean were on ? They should be off during a rain storm.
Basically the same sensor..... just different mounting. Both should come with 25' of wire.
Have tried taking it apart and cleaning the discs ?
What rainfall setting are you using ?
Old 08-10-20, 07:01 PM
Yes the sprinklers were on when they should have been off. I just cleaned the discs as they were dirty but the fact that the test plunger sets off the alert indicates itís working to me? Unless the inner discs have a shelf life
Old 08-11-20, 04:46 AM
P
Received 586 Votes on 540 Posts
Have you set the rain amount to stop watering? On mine I can set how much rain is needed to inhibit irrigation. Many smaller or brief storms don't prevent watering the way I have mine setup.
Old 08-11-20, 06:34 AM
It's set at the sensor and in the middle at .5". The tropical storm should have set it off. I cleaned the interior guts so hopefully that helps. It doesn't appear to be complicated science inside the sensor
Old 08-11-20, 07:37 AM
P
The disks in the rain sensor absorb water slowly. I've noticed that sudden downpours, no matter how much rain, will not trigger the rain sensor. The rain needs to come more slowly and over a longer period of time for it to work properly.
Old 08-11-20, 07:53 AM
You'd think a Tropical Storm which took out power to 40% of NJ would do it
Old 08-11-20, 07:59 AM
We only had 2" of rain here near Morristown.
Old 08-11-20, 08:01 AM
Actually, good point. I think we "only" got 2.5" or so. The wind was brutal though. Either way, I changed it to .5" setting and cleaned the discs so lets see what happens.
