Which movable sprinkler for non circular areas/
Is there a budget style portable sprinkler I can just move around, I have areas next to the deck so do not want to waste water in a circular spread, horizontal if you will. As the water is on tank cant afford to waste it during drought weaher.
How much water does a lawn typically need per month to survive? (Kikuyu). Luckily its a smal 70sqm. I know he tap flow rate so figure I just calculate it off that?
They do make sprinklers that spray different patterns. I have one that dose square, rectangle, long narrow strip and circle. It does a mostly decent job at approximating those patterns on a calm day. If there is any wind the pattern gets blown about.
Only you can tell how much water is needed since we don't know your local conditions. Healthy, established lawns generally don't need watering so any additional would be up to you.
