Hunter Pro C
Old 06-21-23, 01:39 PM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hunter Pro C
Hi All, we installed 2 mini Clik sensors on 2 controllers, one works fine ,one is calling for water although the controller indicates off sensor,, removed sensor wires and ohmed out circuit from sensor, it as closed as it should be however controller still does not function, any thought ? left it in by pass for now.
Geo🇺🇸
Old 06-22-23, 10:57 PM
Received 4,056 Upvotes on 3,639 Posts
The sensor provides a short normally.
When it trips.... it opens the sensor circuit.
Connect the sensor to your controller.
Set rain sensor to normal.
There should be close to 0v AC across the sensor terminals.
I've seen problems where the sensor was extended too far with smaller wire and didn't provide a full short.
