Locating buried sprinkler heads
Old 07-22-23, 08:47 AM
Geochurchi's Avatar
Received 161 Upvotes on 147 Posts
Hi All, I have located a few heads but have no idea how or when it is laid out, my thought was is to remove a head and adapt a hose fitting to the buried pipe, apply water pressure and see where the heads pop up, any other suggestions?
Thanks
Geo🇺🇸
P/S, no backhoe available.
Old 07-22-23, 09:19 AM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Having water come out is the most useful!
Old 07-22-23, 09:39 AM
Kooter's Avatar
Received 88 Upvotes on 81 Posts
Why are you unable to activate the irrigation system to locate the heads? And, why are the heads buried?
That knowledge may help to figure out the situation at hand.
Old 07-22-23, 01:23 PM
Geochurchi's Avatar
System was abandoned, apparently there were too many heads on the zone for it to function correctly, the end was plugged or something no one knows, certainly if I could activate the zone that would solve many problems, I have located at least 7 heads and I believe there are more.
Geo🇺🇸
Old 07-22-23, 01:31 PM
Kooter's Avatar
I understand. I don't know how large an area it covers but heads are almost always separated from each other by an equal distance and located in corners.
Old 07-22-23, 04:49 PM
B
Received 306 Upvotes on 271 Posts
Most lawn irrigation systems have zones such that the water pressure available operates all heads in a zone. Is there a zone controller or solenoid box that might give you a hint as to the number of zones? Is your objective to resurrect the lawn irrigation system?
Old 07-23-23, 04:17 AM
Geochurchi's Avatar
Trying to locate the valve boxes for this area has been a challenge , I understand how the system works just trying to find the buried components.
Geo🇺🇸
Old 07-23-23, 04:23 AM
Marq1's Avatar
Sprinkler heads tend to get buried with debri to the point grass is growing on top, trying to find a dormant head is impossible. If you have found the box you can hook up a compressor to the system and manually open the valve, hopefully that will pop them up!
Is the water hooked up, that would do the same!
Old 07-23-23, 07:22 PM
Tolyn Ironhand's Avatar
Received 893 Upvotes on 754 Posts
If there are wires going to the valve boxes you could get an electrician or somebody with a locator to trace the wires to the boxes.
