Leaf rake shape
Old 03-16-24, 09:57 PM
Received 6 Upvotes on 6 Posts
Leaf rake shape
What is the reason some leaf rakes are flat on the end with all the tines lined up and rakes with the tines in a curved shape? Seems like the curved end will not catch as many leaves.
Old 03-17-24, 03:12 AM
Received 863 Upvotes on 755 Posts
the curved tines make the rake easier to use ....... or have I misunderstood your question?
Old 03-17-24, 05:45 AM
H
Received 297 Upvotes on 255 Posts
The shape depends on what you're raking up: curved are often plastic and used primarily for leaves, straight is usually spring steel and used not only for leaves but also grass clippings, hedge trimmings, or de-thatching a lawn.
sofasurfer voted this post useful.
Old 03-17-24, 09:58 AM
I'm talking this https://www.homedepot.com/p/Anvil-24...5400/307828056 vs this
https://www.homedepot.com/p/Suncast-...600C/315583439
I bought a curved type and, because it is plastic, there is very little flexibility in the tines. Doesn't catch many leaves. I'm taking it back and getting a flat type. If that doesn't satisfy me I will go with the metal cause they have more flexibility. Trouble with that is that metal rakes are expensive and have mostly cheap junk wooden handles unless you want to spend $30 for metal handle. Of coarse I'll spend $10 in gas returning them anyway.
Old 03-17-24, 10:08 AM
I have one like this and use it to rake leaves all the time and occasionally grass. IMO it works well.
