Best grass and everything killer
Old 05-22-24, 01:15 PM
Received 4 Upvotes on 3 Posts
I'm tired of purchasing Roundup and spraying it on my yard and seeing minimal results. What is out there that will absolutely obliterate everything? I want to kill the grass the trees the weeds everything that it touches. Obviously I'm not going to go spray it on my trees but I was using that as a metaphor. I've got a lot of growth around my fence lines and I just want to completely get rid of that. I also have some areas that grass is growing that I don't want it.
Old 05-22-24, 01:18 PM
Received 4,099 Upvotes on 3,682 Posts
The problem is the product you want is not available to the public.
The public can only buy the weak watered down versions.
Look like Tractor Supply sells some HD products to the public.
Old 05-22-24, 01:48 PM
You got a picture?
Old 05-22-24, 02:07 PM
RM43 - total veg killer
Old 05-22-24, 03:18 PM
Tolyn Ironhand's Avatar
Received 899 Upvotes on 760 Posts
Roundup takes a while to kill the plant but it will eventually work. I like Spectracide grass and weed killer concentrate. Typically you see results in about 4 hours. Just be sure to mix it at the highest level.
The farm stuff is also very good.
Old 05-22-24, 03:40 PM
P
Received 2,265 Upvotes on 2,018 Posts
Do you want a product that simply kills everything or do you want a product that also has a residual affect to prevent things from growing/germinating in the future?
Old 05-22-24, 06:35 PM
Received 1,280 Upvotes on 1,218 Posts
I have switched to a product called Dura Zone, not sure what the actual ingredient is. I took a while to work but it eventually killed everything I sprayed it on in just one application.
Old 05-22-24, 08:23 PM
I don't want it coming back. Like when the parish sprays our ditches whatever they use kills everything eventually. This is even with water in the ditches.
Old 05-23-24, 05:39 AM
P
Products containing prometon (Pramitol) will kill all non-woody plants and prevent regrowth for a year or more. You may have to add another chemical to also kill grasses.
