Go Back  DoItYourself.com Community Forums > Garden and Outdoor Center > Lawns, Landscaping and Outdoor Decor
Reload this Page >
Can I use stainless steel water hoses to connect to pvc pipe?
Old 06-30-24, 11:31 AM
D
My Grundfos MQ Series pump finally gave up after 15 years. The cost of fixing was going to be as much as a replacement so I purchased a RainFlo MHP50. The inlet and outlet ports are in different locations so I need to re-plumb the connections to the pipe coming from the rainwater catchment tank and the pipe to the drip irrigation system. The pump has a 1" metal female input and 1" plastic male output. Is it OK to use these flexible stainless steel hoses to connect to the existing threaded male pvc fittings?
Edit: 'Can I use' not 'Can I usu'
Old 06-30-24, 12:20 PM
Received 1,288 Upvotes on 1,226 Posts
As long as they can move the required amount of water per time, I don't see an issue.
