Fluorecent Light that won't work
Old 02-08-04, 07:03 AM
joemcmanus
I have two "U" shaped fluorescent lighting fixtures in my basement (2 bulbs per fixture; fixtures are about 20 years old). Sometimes they work but most of the time it doesn't seem that the bulbs are getting enough power to come on. There is a faint glowing at the base of the light where the two prongs plug in. Is there anything I can do without having to replace the fixture? I have tried new bulbs but still no good.
Old 02-08-04, 07:07 AM
jeremy1tn
Old 02-08-04, 08:37 AM
joemcmanus
Thanks for your quick response. I just switched a ballast from one that is working and it seems to be OK. Have to go out a buy a new ballast. Thanks again.
Joe M.
Old 02-08-04, 10:42 AM
jeremy1tn
Glad to give you any help I can.
Old 02-08-04, 03:41 PM
Received 477 Upvotes on 393 Posts
Check out new fixtures while you are at it. It is often cheaper to buy a new fixture than a ballast.
