Light Fixture Wiring
Need assistance
hello everyone.. I am in the middle of a bathroom remodel. and want to add four recessed high hats to the ceiling of my room. there is a lil wall so i wanted to add 2 on one side and 2 on the other.. I have an existing light with a switch. I want to add a sexond switch to control 2 of the lights for the shower . and use the existing switch to control the 2 outside the shower.. i rean new wire from breaker box. how and in what order may i connect all of this.. thanks
Does the new feed come in at the switch box? If so then 2 lines need to go from the switchbox to the 1st fixture on each side.Then from the 1st to the 2nd fixture on each side.The most important thing is to make sure the fixtures you get are listed for damp/wet locations {i.e showers,bathrooms,etc}They should also be on a GFCI circuit.This can berdone by wiring a GFCI receptacle before the switch for the lights with the feed that you ran.If you need more info post back.
