Recessed lights & insulation
Old 05-10-04, 08:59 AM
eheraux
Question Recessed lights & insulation
I'm looking to install a recessed light above my shower. I've purchased the cannister and the light convering (which has been certified for showers). The instructions say that I need at least 3" of clearance between the cannister for the light and any insulation, otherwise it's a fire hazard. Should I just cut a chamber into the insulation inside the ceiling so that there's enough space/air around the cannister(which is just plain metal, I think aluminum)? Is that safe enough? should I build some sort of box/casing around the cannister? Should I get some other type of cannister made to cozy up to insulation? WHat are my best options here?
Thanks for any help,
Ed H.
Old 05-10-04, 10:05 AM
You must follow the instruction and keep the insulation clear. I ould reccommend you replace the fixture with on that is rated for contact with insulation.
