Installing Pressure Switch
Old 05-20-04, 05:36 PM
I want to put a pressure switch (if that is the name of it) on a cabinet door so the light will come on when the door is opened and shut when closed. I have only been able to find a real large switch that would be for a full size door or a little mini switch. The little switch is rated for the wattage and such but it doesn't come with an enclosure. It is just the switch with two connection points. I want to know how to inclose it so it will be safe. I have thought of making something from PVC pipe but am not sure this would be safe. I have shopped at HD and Lowe's and an electronics store to find the switch. Only the electronics store has something suitable but no enclosure. HELP.[/B][/B]
Old 05-21-04, 08:09 PM
ampz's Avatar
You may have to get a 120v "Normally Open" switch & mount a box to the inside of the cabinet.A good electrical supplyhouse should have what you need.You will then need to make a bracket { an "L" shaped piece of any rigid material} to mount to the inside of the door to shut the light off when the door is closed.I apoligize if this explanation seems vague,I hope it helps.
Old 05-21-04, 09:08 PM
Of course, the other option is to use a 120V relay instead of a 120V switch - this would allow you to mount the relay out of sight.
Good luck!
