Motion Sensor Light Stays On
Old 08-27-04, 02:53 AM
New Member
I have an exterior light with a motion sensor and a 'daylight sensor'. Once it get dark it goeas on and keeps getting turned on constantly.
Can the sensor be bad? Am I better off replacing everything?
thanks,
Old 08-27-04, 06:34 AM
Received 1 Upvote on 1 Post
Is this light on a switch? Are there more than one light on the same switch?
Old 08-27-04, 06:49 AM
New Member
I know there are other things on the circuit. But this light has been there for about 2 years and this just started happening last night. The light keeps going on as if there is something there. I checked a couple of times and there wasn't anything there.
Also, there isn't a switch for the light, it has constant power.
Old 08-27-04, 07:06 AM
Probably best to just replace the fixture.
Old 08-27-04, 02:21 PM
Received 518 Upvotes on 423 Posts
Was it windy? Tree or shubs blowing in the wind will trigger it. Is there a heat source that might be triggering it?
Old 09-01-04, 07:44 PM
New Member
Thumbs up
I replaced the entire fixture and it works fine. I think the sensor went bad. A replacement sensor costs $20, the entire fixture cost $12. So I replaced the fixture.
