help
Old 08-28-04, 09:16 AM
knife
Unhappy help
i have a problem lol... i have 2 octagon boxes box 1 has the feed in it ,2 wire.
i ran a 3 wire to box 2 and then down to the switch . i want to have both lights work at the same time and the fan to work seperately . is there a way that i can wire this or do i have to change the wire to a 4 . please help
knife
Old 08-28-04, 09:25 AM
Does box#1 have a simple light, and box#2 have a fan with a light kit? And you want the wall switch to turn on both lights, and then be able to turn on the fan motor with the pull chain, independent of the switch? Is this all correct? And you ran black/red/white cable from box#1 to box#2, and also ran black/red/white cable from box#2 to the switch box? All true?
