Corrosion causing breaker to trip?
Received 0 Votes
Unknown to me,when it rains hard,water has been leaking down the wall onto a switch in the wall.The switch controls a light that is always on at night.The other day,the breaker trips for the first time.When i inspect the switch,the ground wire is very corroded from the water.Will this trip the breaker or is there a short somewhere else?
Received 0 Votes
Corrosion can cause an open circuit, but I don't see a reasonable way it could cause a short. I'd still bet on the moisture, even after a dry week. I'd be more concerned about mold than electrical problems.
Received 0 Votes
My guess would be moisture in the switch itself, which has corroded internally to the point that it now shorts to the mounting strap. I'd change the switch and see if the problem goes away.
Check for water in the light box as well - pretty common, especially if the light is not coverd by a roof overhang.
