120 to 12 volt transformer at 20 Khz
Old 12-29-04, 04:46 PM
terrance phil
Question 120 to 12 volt transformer at 20 Khz
My question is: Why do many manufacturers of small lighting transformers (70 watt) convert to 20kHz at 12 volt output instead of using a 60 Hz transformer? Does it have to do with the ability to use halogen lamps or perhaps a size reduction method to keep the transformer smaller ?
Old 12-30-04, 09:13 AM
The answer is pretty
much what you've already guessed, the higher the frequency, the lighter and smaller the transformer can be. It's also possible that this isn't a "transformer" at all, but the inductor for a switching power supply.
Hope this helps!
Old 12-30-04, 11:21 AM
A transformer doesn't change the frequency... only the voltage. What you porbably have is a switching power supply. The idea is simple, the higher the rectified frequency is the easier it is to filter the ripple voltage and the better (closer to real DC) the output voltage is.
Plus, switching mode power supplies are much smaller and cheaper compared to "regular" power supplies using transformers.
