modifying a light fixutre...
I have a wall light fixture that needs replacing. The switch is located on the fixutre itself. I don't want to add a new switch to control the fixture. Can I modify a new light fixutre by adding a switch to it? - ie. drill a hole and add switch.
I would be reluctant to add a switch to the fixture itself. Unless you are a lighting designer, you might create an unanticipated hazard. I suggest you look harder to find a suitable fixture with a switch already on it, or install a regular wall switch near the light.
The X-10 powerhouse people have some slick wireless ways to accomplish this.
Check www.smarthome.com for ideas.
