dim, flickering lights
Old 02-18-05, 09:02 AM
jdenis
I have replace one tube in a two tube incondesent light fixture. both tubes now are very dim and flicker constantly. any suggestions on why and how to fix?
Old 02-18-05, 10:20 AM
Received 1 Upvote on 1 Post
Always replace all the bulbs in a fluorescent fixture at the same time, even if only one is having trouble.
I'm not sure I understand your question. You use the word "tube" which suggests fluorescent, but also use the word "incondesent" which suggests not fluorescent.
Old 02-18-05, 11:03 AM
jdenis
you're right! thank you
you are right, I'm a fool. I meant flouresent! I just replaced the other bulb and it worked! any reason for this, replacing both bulbs even though one appears to be fine?
