Cutting Hole for Recessed Lights
Old 03-04-05, 08:23 AM
I'm doing a basement renovation and will be installing 6" recessed lights (new construction style). I'll also be installing drop ceiling tiles. What is the best method for cutting the 6" diameter hole in this material?
TIA
Joel
Bayside, NY
Old 03-04-05, 10:28 AM
pgtek's Avatar
Received 1 Vote on 1 Post
hi
you can buy a hole saw.
It mounts to your drill you can buy it at hd or lowes and come in diffrent size
pg
Old 03-04-05, 11:38 AM
robertnb64
I agree, buy the hole saw. I did them by hand at first, not worth it.
Old 03-04-05, 01:52 PM
Is there a 6" hole saw?
I've only seen them up to 5".
Joel
Old 03-04-05, 02:44 PM
Because the can has a trim, the hole need not be perfect. You could probably cut it with a kitchen knife or any other tool which would cut this material.
Old 03-04-05, 06:22 PM
Speedy Petey's Avatar
Use a drywall keyhole saw. A hole saw or special recssed light saw is way overkill to do one job.
A keyhole saw works perfectly. I do it all the time.
