Not sure which which is hot and which is neutral
Old 03-08-05, 09:26 AM
HenryM
Lightbulb Not sure which which is hot and which is neutral
I want to replace a light fixture in my kitchen, however, I can't see a distinction between the hot wire and neutral white wire.
Any suggestions?
Old 03-08-05, 09:52 AM
Received 1 Upvote on 1 Post
On the fixture, or from the ceiling?
Old 03-08-05, 09:53 AM
HenryM
From the ceiling
Old 03-08-05, 10:32 AM
pgtek's Avatar
hi
turn switch on
get a prong electrical tester and touch one wire and with the other end of the tester touch the electrical box.
the one that lite is the hot wire
cheers
pg
Old 03-08-05, 04:07 PM
pg's advice will work if you have a grounded metal box. Unfortunately, many older homes do not. Visit your home center. Spend $15 on a voltage "tick" tester. It will easily tell the difference between the two wires, without the need for a ground. And it's kind of fun to use to boot.
Old 03-09-05, 07:37 AM
HenryM
Thanks guys. I appreciate the advice
