Wall Light Problem
Old 03-13-05, 06:54 AM
erskine
Wall Light Problem
I have recently replaced a wall light. The new light takes 2 candle 40W bulbs but keeps blowing the bulbs. I have checked the wiring and it seems to be fine. I have changed the light but it makes no difference.
Any idea what could be causing this problem? Another strange thing is that one original bulb has never blown.
Old 03-13-05, 09:21 AM
Do the bulbs install base up, or base down?
Old 03-13-05, 11:10 AM
erskine
Not sure if I follow you. The light is a picture lamp and the bulbs install from centre out (horizontally).
Old 03-13-05, 03:37 PM
Okay, as far as I know, all of these bulbs can be installed horizontally. You may just have run into a bad batch of bulbs. Buy a different brand from a different store.
Old 03-13-05, 11:45 PM
erskine
Thanks, John. I've actually used bulbs from 3 different suppliers now. I will try using 25W bulbs and see if that makes a difference.
Old 03-16-05, 09:36 AM
erskine
Tried small 15W bulbs and they made no difference.
