Basement Stair Lighting
Received 0 Votes
I've got a 13-step stair down to the basement (which I am finishing right now). There is currently only one light in the stair area, which is located at the bottom of the stairs and can't really illuminate all the steps. I want to add one more light to the upper part of the stairs and would like to get some opinions. Thank you.
Received 0 Votes
Originally Posted by pgtek
hi
install a light at the top of the stair and have both lights on a 3 way switch
I've seen some kind of "recessed wall light" in my neighbor's basement, which is mounted inside the side wall. I am not sure what's the official name for it and where to get it.
Received 0 Votes
If you are finishing the basement then won't you also be finishing the "The ceiling is really just the back of the stairs from 1st floor to 2nd floor"? Finishing the back of those stairs should allow you to install a light. With the basement ceiling not yet finished it should also be fairly easy to run a wire up the wall and out to the new light.
Received 0 Votes
Sorry, I forgot to mention: that area was already drywalled along with both sides of the basement stair, when we moved in.
