Low Voltage Outside Lighting
Old 06-26-05, 09:18 AM
michaelshortt's Avatar
I am installing a low voltage lighting system in the front of my home. The transformer is installed on a GFI protected outlet. The instructions say to install the first light a minium of 10 feet away from the transformer. I am wondering if that is a shock issue or what? I have about six feet.
Old 06-26-05, 11:23 AM
pcboss's Avatar
Received 175 Upvotes on 153 Posts
The voltage drops the farther you are from the transformer. Too close and the lamps will get too much voltage and burn out.
Old 06-26-05, 04:15 PM
D
pcboss is correct. However, the distance they are talking about is the length of the wire, not the physical distance of the lights from the transformer. If you want the light 6' from the transformer, just run 10' of wire and put a couple of loops in it.
