Hunter's plastic breakaway chain connector
Old 06-28-05, 01:00 PM
graham01
Well the Hunter fan install is fine, done a few before, but now I'm defeated! Just how does that breakaway plastic connector for the pullchain connect to the chain?
I can see the two parts plug together but short of glue, I have no idea on how the chain joins to the plastic parts.
This, I can tell, is going to be one of those real obvious ones and I'll feel stupid for not being able to see it - but it happens.
Graham
Old 06-30-05, 05:46 PM
graham01
I know what the problem is!
I just put in another Hunter fan and in this case had to connect wires from the lighting assembly to the lighting box. These wires were fitted with these little plug-in connectors.
In the previous fan, there were a couple of these loose in the kit, but no use for them. These were the parts I assumed were the plastic breakaway connector. Now I realise that the "breakaway connectors" were just the usual chain connectors but in plastic.
OK, feeling dumb but wiser,
Graham
Old 06-30-05, 09:13 PM
I'm glad you were able to answer your own question for yourself, and us. I had no idea. Thanks for reporting back.
