Need infrared lamp fixture
Old 07-06-05, 12:20 PM
R
Anybody know where I can get an infrared heat lamp recessed housing? I don't want one of the combo units like the ones made by Nutone, or others, I just want an independent housing, similar to the 6" recessed light housings.
I'm pretty sure I've seen them installed in hotels and such, but I have searched high and low and cannot find anything to suit my needs. The closest thing I've found is the 6" recessed light housings, but they are only rated for a max of 150W, and these heat lamps are 250W.
Thanks...Randy
Old 07-06-05, 02:58 PM
G
Received 2 Votes on 2 Posts
You could Google the net and see if there is anything out there. I would go with an approved fixture like the Broan / Nutone. Square trim is not ugly and you could run the exhaust fan or not.
Old 07-06-05, 07:11 PM
R
Hmmmm, I see this is going to be a tough one.
I have already googled yahoo'd, msn'd and a couple others. I've searched at HD, Lowes, and a couple hardware stores, to no avail.
I may end up having to go with one of the approved fixtures, as you suggested...much to my dismay.
Thanks for responding.
Old 07-06-05, 07:26 PM
G
You could check this site. However, they look about the same as the Nutone and only a couple of bucks cheaper. It's almost like getting the exhaust fan free with the Nut One model.
http://www.infraredheaters.com/bathheat.htm
Old 07-06-05, 07:27 PM
ampz's Avatar
A good local electricalsupply house should have them in stock or atleast order you one.The 1st manufacturer that comes to mind is Progress Lighting
Old 07-06-05, 10:52 PM
C
You fixture you want is a a Halo H37T-401AL. 250 watt, heat lamp rated.
Spec sheet here: (It's a PDF document - you'll need Adobe Acrobat Reader to view it.)
http://www.cooperlighting.com/specfi...42509_H37T.pdf
Any Halo dealer should be able to order it for you.
Old 07-07-05, 04:19 AM
R
Exactly what I am looking for, Cheyenps.
I think I'm going to have to reevaluate my search techniques, cause I searched their site a couple times for this and it never turned up for me.
Thank you very much for finding it for me.
Randy
