getting shocked
Old 08-14-05, 04:15 PM
oma112
Question getting shocked
While working in the yard I noticed that I was getting a mild electrical shock when working around the post of our yard light if the ground was damp. Soon after this all the flowers I had in this area died. The light is joined into a circut from the house and when my husband replaced the ceiling fan and light that is on this circut it started blowing the breaker on a very regular basis and we would get a popping sound when it blew. (the breaker is now turned off at all times.) On this circut we have 1 cieling fan and light 4 other ceiling lights and several plug ins including the one we use for our TV. The wire to the yard light was run through plastic pipe. We do not know where to start looking for the problem, and have not recieved a single responce from multiple calls to 3 different electricians.
Old 08-14-05, 09:37 PM
Sounds to me like the underground wiring feeding the post light has gone bad. The fact the fault started showing itself afteryou installed the fan could be just a coincidence.
I'd disconnect the line to the yard light and see if the problem goes away. If it does, you'll have to pull new wire out to the yard light.
Old 08-15-05, 07:50 AM
You say that the breaker is off at all times, right? So that means that the ceiling fan and light, the post light, the television, four other ceiling lights, and the receptacles are dead all the time--including when you got the shock?
If the breaker is turned off, I don't see how the shock can be an electrical problem with that line.
Something strange is going on and it could be any of a number of things. You probably need a knowledgeable person on site to take a look.
