overheating halogen magnetic transformer
I recently installed a low voltage halogen rail lighting system which utilizes a magnetic transformer. It is on a 3 way switch with 2 seperate fixtures.
The transformer seems to be overheating after using for several hours--ie, it gets almost too hot to touch and you can smell it overheating. Could this be caused by using an incandescant fixture with 3x 25watt bulbs on the same 3 way switch? I have checked all the wiring connections and rail connections several times and everything is tight. The ligts seem to function fine otherwise. I planned on using the same low voltage halogen fixture as the other fixture on the switch (would have 2), but dont want to spend more time installing before I figure out the problem. Is there an easy way to troubleshoot this? Thanks.
