Replacing existing fixture with recess lights
I want to replace my flush mounted indoor lights with recess lights (remodel type) . My question is how to easily remove the existing metal junction box so I can put the recess light in same location. I'm sure the junction box has other pipes attached to it. Thanks.
Is your house wired with conduit? Do you live in the greater Chicago area?
Once you cut the hole for the recessed light, you should have plenty of clearance to remove the box.
