Rough-in box sizes
Rough-in box sizes
Hi I'm getting ready to wrap new construction with just the exterior boxes roughed in. (Inspector gave me the go ahead) What size boxes do I use for exterior lamps? (backdoor or carriage) 4" square, 4" oct., 4 1/2"? or round? I noticed many different sizes at Home Depot. Also do I need a box for a door bell? Can I use a regular box for exterior GFCI outlets and just use a waterproof cover? Lastly, what about security cameras video/power? box or just poke through cable. Thanks.
Most fixtures can mount to either rectangular or round boxes. But why take a chance? Buy the fixtures and read the installation instructions. Or don't buy the fixtures and read the installation instructions in the store.
Make sure you set the boxes far enough forward that they flush up with whatever siding you will be using.
One more little trick - use DB rated wire nuts for any connections made in exterior boxes. No matter how well you try to seal them, they always get damp. With DB (direct burial) wire nuts, the connection will last forever. DB wire nuts are large, so use deep boxes wherever possible. A dab (a little dab - the stuff makes a mess if you get carried away) of Noalox on the wire before you connect it to a receptacle will also help to make the installation last.
Have you installed the exterior boxes for CATV and Telephone? Check with your local provider for specs - sometimes they will give you the box they want you to use. Have you installed an access for the connection to the UFER ground?
4x4 boxes are nice. The deeper the better. You can put any mud ring you want on top and they leave you a little wiggle room. Round mud rings are tapped for 8x32 fixture screws so they can handle heavier fixtures, and you may find the mounting bar easier to deal with on the round box. I think the NEC allows light fixtures to be hung on a rectangular 4x2 box with 6-32 screws, but to a lower load than the 8-32 screws. A metal mud ring's threads won't strip as easily as plastic, in my experience.
These require a deeper mounting depth of the 4x4 box, though.
Good luck.
