Buzzing sound in light fixture...with dimmer.
Light fixture in dining room buzzes lightly when on high and louder when dimmed. As you can tell, it's on a dimmer switch. I read that buzzing sounds could be fixed by an adaptor installed in the fixture, but I was wondering if there would be an easier fix. Is it possible that I could pick up a voltage regulating dimmer switch for the fixture to fix the problem? Are there such things and if so, what should I look for in another dimmer switch? The dimmer switch that's installed was there when I purchased the house, so I'm not sure about it.
Thanks in advance to anyone that could shed some light here. (no pun intended, but happened just the same)
