Can I tap a pull chain socket light?
I have a pull chain incandescent socket in my attic near the entry hatch. It has a receptable (to plug in something). I don't know what you call it. Can I plug another lamp into it, a shop light or something like it?
Can I remove this receptacle and run wire to the center of the attic and add a switched light fixture, the switch being where the old socket currently is.
Thanks.
Thanks.
If NM cable is allowed in your city, then if the circuit is protected by a 15-amp breaker, use 14/2 NM-B. If the circuit is protected by a 20-amp breaker, use 12/2 NM-B. Read two books on home wiring before beginning.
