low voltage question
landscaping light, but I thought I'd hit this forum since it is electrical question.
i recently added some lights onto my upgraded power pack/transformer. i did not exceed the load. they worked great for a week or more. the day i buried them i decided to insure the waterproof wire nuts by wrapping them in electrical tape. still fine. i proceeded to bury the line with the splice. while doing so the lines started to smoke from beneath the earth. i quickly ripped up the line and pulled apart the melting wires.
I took a new run of wire and attached a light directly. nothing. i check the breaker and the outlet. both fine. i checked the transformer with a meter. nothing. the eye sensor still works, but I suspect that runs off 110 not 12v.
Perhaps the wires we nicked somewhere. don't know.
Onto part 2 of my problem. This was a Toro outdoor light power pack. they no longer make them and the company that used to sell replacement parts is no longer around either.
What other quality brand can I use that is compatible? Suggestions?
All of the brands are compatible, as far as I know. I've been satisfied with Intermatic in the past - quality is aceptable and price is not out of line.
Did your Toro unit come with a fuse on the low voltage side? I've never seen one that didn't, and it's very possible that a blown fuse is the only problem you have. Some have a little circuit breaker - have you tried to reset it?
I don't see one. The only switch on the back is for 4-6-8hrs or dusk to dawn. the unit is imprinted with a warning.
WARNING:to avoid electrical shock do not open. no user servicable parts inside power pack.
thanks for the info on compatibility. guess it's time to go shopping. OY! 2nd transformer in a year. at least the first lasted 10yrs. this one barely made it 1 year. i guess i toasted it. still don't know what i did wrong. i'd hate to blow more money by smoking another.
