Putting 2 lights where there was 1 before
I'm setting up my garage to be a woodshop. I need a lot of light. I want to install 2 8' fluorescent light strips. All that I've got in there right now is a regular light bulb.
Is it possible to power those 2 strips with the wiring in place for that single bulb?
Yes, you'll need an extension ring {4" or 3" round....?} for the existing box if its not surface mounted.Then I would run MC cable ,the same gauge as the existing wiring {MC is like BX only with an insulated ground} out of the box to each fixture.You can also use EMT conduit if you like,runnig cable is hard to keep straight especially in a long run on a ceiling.
So when I pull off the existing light, I'm going to see one set of wires. Do I just attach both MC cables to the existing wires at the same time?
I'm new to this, and am trying to learn about wiring in general. I don't want to make any misassumptions. If anyone is willing to walk me through it at a dumbed down level, I'd appreciate it.
