Buzzing noise from chandelier on new dimmer switch
Received 0 Votes
Hello,
We have a chandelier that uses 5 standard lightbulbs (60W). I just istalled a dimmer switch and now there is a buzzing noise comming from the light fixture (I assume from the bulbs). The dimmer switch was rated for 600W, if that means anything here. The noise isn't horrible, just loud enough to bug me. It does get slightly louder the dimmer the lights are. Is this normal? Are there bulbs I can use that won't buzz?
Thanks.
Thanks.
What type of dimmer switch is it? Is it a $2 old fashioned resistance type where you push the round dial for on/off and turn for dimming, or is it a more modern electronic one?
Received 0 Votes
"What type of dimmer switch is it? Is it a $2 old fashioned resistance type where you push the round dial for on/off and turn for dimming, or is it a more modern electronic one?"
It is a toggle switch with a slider bar along the side that is the dimmer. It cost $18 at a big box home improvement store.
Received 0 Votes
Originally Posted by John Nelson
Try a different brand and/or type of bulb.
Received 0 Votes
Follow up - Solution found
As Classicsat stated, the problem seems to be in the quality of bulbs:
Westinghouse contractor-supplied (read cheap) bulbs = loud buzzing
Phyllips Duralast bulbs = almost no buzzing
Thanks to everyone for their help.
Received 0 Votes
thanks to Dim Bulb
Saw this thread and your answer -- bought the Halogena and they are SILENT! I thought I would just have to live with the buzz and I can't believe the change -- Thank you, thank you, thank you.
