Adding a ceiling fan to a room w/ no ceiling wiring
Old 12-19-05, 10:12 PM
Ndel40
I would like to install a ceiling fan in a first floor room that does not currently have a ceiling fixture installed. There is a bedroom directly above and a basement directly below the subject room.
The only problem is the floor joists in the subject room ceiling are running the wrong way...therefore I do not have a clear path to run the new wiring to the center of the room. I would like to keep damage to the ceiling and walls to a minimum.
Can this project be completed or is it a lost cause??? If additional information is needed please let me know. Thanks.
Old 12-20-05, 10:42 AM
A
Is the underfloor space accessible? If so can you run underfloor between the desired switch location, perpendicular across the basement ceiling joists, then fish up thru the wall, cut in a handhole, drill thru the top plate, and then parallel a "wrong" way joist to the center of the room?
Otherwise you can use wiremold, but then you're going to have a small raceway across your ceiling.
Whatever you do, use 14/3 or better so you can control the fan and light separately from the wall switch, use a fan-rated box and hang the fan-rated box from suitable framing or a fan-rated crossmember.
A handhole can be covered with a wall plate and painted or wallpapered to match.
