Light on ceiling fan broke
Old 01-09-06, 06:35 PM
I was tightening a bulb on a ceiling fan (with the light on) and the bulb blew out. The lights all went out and now they won't go back on. The fan still works. All the circuits are fine. It is an older Leviton fan and light. Does anyone have any suigestions about whether this is a fixable problem?
Old 01-09-06, 07:20 PM
Received 111 Votes on 101 Posts
Did you check the breaker. It is possible that the fan and light are on different circuits. If not the breaekr then a loose connection in the fan box.
Old 01-09-06, 07:39 PM
Yes, circuit breakers are all fine.
Old 01-09-06, 10:17 PM
Check the switches.
Old 01-10-06, 06:00 AM
How, where do I do that?
Old 01-10-06, 07:32 AM
Does your fan have a remote control?
Old 01-10-06, 01:01 PM
This was my problem when the same thing happened. To check for sure, disconnect the remote and they connect the supply to the fan. If the light works, then it's the remote.
Old 02-21-06, 01:28 AM
You never answered if it had a remote or not. That would be my first bet. Second, is a bad connection within the fan's switch housing, or a bad switch on the light kit.
Levitron never made fans, just the switches inside them.
MEMBER BANNED FOR ADVERTISING
