Dimmer on a 3way
Old 01-24-06, 07:53 PM
T
Dimmer on a 3way
I want to install a dimmer switch on 3 way lighting in the attic, but only want to do this at the top switch and leave the one at the bottom of the stairs as a regular switch.
My question is will this work ok and what if the dimmer is only left half way and I switch on from the bottom - will this only then switch the lighting on only half way...??
I just want to find out if I need to purchase 2 dimmers or 1.
Thanks very much.
Old 01-24-06, 08:24 PM
C
Two ways to do this.
The first is as you describe. Use one dimmer and one three-way switch. The dimmer will dim and switch; the three way switch will only turn on the lights to whatever dimming level the dimmer is set at.
The better way is to use three-way electronic dimmers - one "Master" dimmer and one "slave" dimmer. Now you can switch and/or dim from either end (and they look trick, too...)
Old 01-25-06, 05:55 PM
T
I guess the electronic dimmers would be pretty pricey, so I'll probably go with the other option.
Thanks for taking the time to reply.
