Wiring Help PLEASE!!!
I am remodeling my condo and I have installed a fixture (ceiling fan) in the ceiling where none existed before. I have a light switch that operates a receptacle and the power source goes directly into that receptacle. I would like to:
1. Convert the receptacle so it stays hot constantly
2. Wire the existing light switch to supply power to the ceiling fan
How should this be wired? Thanks in advance for your assistance
Tre'
Tre'
This should be possible.
Please provide details as to how the receptacle box is currently wired. How many cables come into the box, what are the colors of wires in each cable, and what is connected to what? Also, are both halves of the receptacle switched, or only one half?
Does your new fan have a light too? What are the colors of the wires from the fan?
Receptacle box currently has one line (black, white, ground) into the box. As of now, neither receptacle is switched since I removed the wires from the toggle switch. The fan has a light. Wires are black, white, and blue/green.
I need to use the power source from the receptacle to feed to the ceiling fan, but operated (ceiling fan) by the toggle switch.
Tre',
Based on the information you have provided, the electric cable runs into the switch and then to the wall outlet.
Like Joed said, you will need to run a new cable from the switch up to the fan (12-3 or 14-3 Romex should be fine). Once you do that, you will have three cables running into the switch box.
Cable 1 runs from the electric panel to the switch box.
Cable 2 runs from the switch box to the outlet.
Cable 3 is the new cable that runs from the switch box to the fan.
Here is how to connect the wires inside the switch box to make it all work:
Connect all the white (neutral) wires from cable 1, cable 2, and cable 3 together. Twist the wires together in a clockwise direction and cap with a wire nut.
Connect all the bare (ground) wires from cable 1, cable 2, and cable 3 together. Take a small length of bare wire to make a "pigtail", which you will connect in with the other bare wires. Twist all four wires together in a clockwise direction and cap with a wire nut. Connect the bare "pigtail" wire to the ground post on the switch.
Connect the black (hot) wires from cable 1 and cable 2 together. Take a small length of black insulated wire to make a "pigtail", which you will connect in with the black wires from cable 1 and cable 2. Twist all three wires together in a clockwise direction and cap with a wire nut. Connect the black insulated "pigtail" to the lower pole on the switch. Connect the black (hot) wire from cable 3 to the upper pole on the switch.
At the fan, connect the wires as follows:
Cable Wire Fan wire
Black -------------> Black
White -------------> White
Bare --------------> Green/blue
Best wishes.
Rick
Cable Wire Fan wire
Best wishes.
Rick
