Bathroom Fixture Issue
Old 02-13-06, 09:09 AM
Question Bathroom Fixture Issue
Appreciate any help here.
I have a light fixture with 3 bulbs in my bathroom. The middle bulb often crackles and flickers for several minutes before acting properly while the other 2 have no issues. Should I simply rewire my fixture (loose wires for center bulb???) or is it simply broke and I need to buy a new fixture?
thanks!
jake
Old 02-13-06, 09:17 AM
Assuming that you have changed the bulb already, I would shut of off the powew at the breaker and disassemble the fixture looking for loose connections or chafed wires. Make sure the connections are made securely using the right size wire nuts (give them a tug test).
Old 02-13-06, 09:40 AM
thanks! unless there is any other advice, I will try that. just wanted to make sure that the fixture was not garbage...yet.
