Gfci Problem
Gfci Problem
Hi, Help! I Was Setting Up My Workshop In The Garage Of Our New House And Hung 2 Fluorescent Shop Lights From Lowes. Very Simple Stuff, But The Gfci Outlet Shut Me Off Everytime I Tried To Plug Them In. It Ran My Drill, And Saw, But Not The Lights. I Went To The Other Side Of The Garage And That Gfci Ran The Fluorescent Lights Just Fine. I Took The Fixture To Several Other Gfci Outlets Inside The House, No Problem. I Then Tested The Outlet That Was Shutting Me Off, And It's Fine. Any Ideas? I'm Planning On Running 2 Compressors Off That Side Of The Garage And Some Powertools And At 61 My Eyes Need All The Help They Can Get. Thanks - John 45
Cheap fluorescents sometimes have leaky ballasts. These can trip a GFCI occasionally. Old GFCIs can also get fooled by fluorescents. But I have had a very cheap fluorescent shop light in my garage for the last ten years, and it's never tripped the GFCI it's on.
I'd replace the GFCI, especially if it is over a few years old. Newer GFCIs are less vulnerable to false trips. It that doesn't work, I'd replace the shop light.
Gfci
Thanks John, That's What I Was Thinking, Replace The Gfci, It's About 8 Years Old. That's Pretty Straight Forward And I Should Be Able To Do It Easily Enough. I'll Let You Know. - John 45
