Keep blowing fuses!!!
Received 0 Votes
The ceiling light in my bedroom had not been working for awhile so I decided to change the light switch and the ceiling light. However, after installing them fuses continually were blowing (still use screw fuses). I unwired everything and just capped off the wires and made sure nothing was touching but fuses keep blowing or they are screwed in but there is no voltage coming through, as I tested with the voltage detector. What could the problem be?
Received 0 Votes
Received 0 Votes
When you had the fan installed, and the fuses were blowing, did the fan/light work before they blew?
Another question: when you cap off the wires, do the fuses still blow?
There are so many factors here. The problem is somewhere between the breaker box and the outlet box. It could be bad wiring, or a bad connection, or . . . something's bad in there. If you're even the slightest bit uncomfortable with troubleshooting this, call an electrician. You're dealing with things that can burn down your house.
Lastly, when you get any problems outside the fan itself straightened out, make sure the fan is wired correctly.
MEMBER BANNED FOR ADVERTISING
