track lighting vs. low voltage track lighting
Hello everyone,
This is probably a stupid question. Are track lighting and "low voltage track lighting" the same thing? If they are not, what are the differences (pros and cons of each)? Thanks in advance for your help
No asked question is stupid. It shows you want information. Basically the line voltage track lighting requires rigid wiring configuration through junction boxes, and uses 120 volts. Low voltage uses a transformer with an output of , say, 24 volts. It requires smaller wiring that can be hidden more readily, and the boxes don't have to be enclosed as do the line voltage units. Both lights put out the same lumens in halogen, and the same heat, so you won't gain any cooler lighting by going with the low voltage lighting. I prefer low voltage, especially for hockey puck lighting under cabinets. Special low voltage switching will need to be installed for the low voltage units, if you decide to split them off the same transformer.
For track lighting, I would go with line voltage, since your wiring is probably already there.
Hope this wasn't too wordy.
Thanks, Larry, for the info.
Is it true that you have to get track light heads and tracks made by the same manufacturer?
I'm thinking of converting an existing light fixture above the fireplace into track lighting for the entire family room. From what you told me, the line voltage track light would be the preferred choice. Is there a limit on how many track light heads I can put on?
Thanks so much for you help.
Owen
Owen
Owen: with all the manufacturers of track lighting, there may be a difference in the way they fit together, so, yes, I would match the track with the lights.
You are correct in installing line voltage track lights in an existing situation. You can install as many as the amperage will allow. Most likely 4 60w lights will suffice for a 4' section.
If you like the looks of the low voltage systems then use them. All you would need is a canopy mounted transformer for the low voltage track, it would require no more re-wiring then using line voltage tracks.
you can check out Juno, tiella, or Teck lite for low voltage tracks.
